Group: DynoMotion Message: 6898 From: Jad Rizk Date: 3/8/2013
Subject: inch-mm degree
Hello Tom,
I am using 5 axis defined in kmotionCNC, x,y,z,a,and b.
X,y and z are linear a and b are angular in degrees
How can I keep the same values of a and b in kmotioncnc when switching between mm and inch
I will be using the machine in mm mode and inch mode, but in both cases i need a and b to be in degrees.
Right now in mm mode if I place the values in degrees the values are correct. When switching to inch I need to divide these values by 25.4 to keep everything correct. Is there a way to just keep them in degrees.
Jad
Group: DynoMotion Message: 6958 From: Jad Rizk Date: 3/11/2013
Subject: Re: inch-mm degree
Hello again,
Does anyone have any idea how to solve the issue?
On Fri, Mar 8, 2013 at 2:24 PM, Jad Rizk <jadrizk89@...> wrote:
Hello Tom,
Jad
Group: DynoMotion Message: 6960 From: Tom Kerekes Date: 3/12/2013
Hi Jad,
Sorry for the delay.  We are adding that feature and should have a new Test Version soon.
